Target Category: Linux
Target Sub-Category: Sim
Description: The Linux RPi PWM for Simulation block is used during simulation to produce a fixed-point value between 0 and 1 that is supplied to the PWM block.
When a PWM input is not connected, the corresponding output on the PWM for Simulation displays a 0 value.
Simulated PWM Unit: Specifies the PWM channel to be simulated.
