Target Category: Arduino
Target Sub-Category: Digital I/O
Description: The Digital Input block receives digital data.
Bit Width: Specifies the bit width.
Channel: Indicates the channel number. Click here for Arduino pin mapping.
Enable pull-up resistor: Enables the pull-up resistor on the input pin to 3.3 V.
Offset: Specifies the offset.
Port: Specifies the port. Click here for Arduino pin mapping.
Title: Indicates the channel title.
