The Generic MCU Config block lets you choose the setting for a generic MCU.
Boot Init Code: Specifies user C code to initialize the chip.
Control Clk Prescale: This parameter is not available for use.
Control Clk Src: This parameter is not available for use.
CPU: Specifies Generic MCU.
CPU Speed: This parameter is not available for use.
Ctrl Clk Count Mode: This parameter is not available for use.
JTAG Connection: This parameter is not available for use.
Multiple of Crystal Freq: This parameter is not available for use.
