There are several housekeeping chores you should perform before generating code from your source diagram on the host computer.
See Also:
Configure the target
Set the integration algorithm
Configure the compound block to communicate with the target
Targets with no floating-point unit
Target devices with no file system
Variable names
Speed considerations
Code generation considerations for low RAM targets
Determine stack and heap use
Blocks that generate stand-alone C code
