Target Category: Linux Raspberry Pi
Target Sub-Category: SPI
Description: The SPI Read block is a serial peripheral interface block for receiving data from certain hardware chips, like analog I/O chips. Use SPI Config to configure the hardware settings.
Additional information: Using SPI slave to communicate between two Launchpads.
Block Output: Determines the type of information the block receives.
Data: Data bits received.
Port Status:
Hardware status.
Receive Queue Empty: True if empty.
Receive
Queue Length: Specifies the length of the receive queue.
Receive Queue
Max Length: Specifies the maximum length of the receive queue.
Receive
Queue Overrun: True if queue has overflow.
Transmit Queue Full:
True if full.
Transmit Queue Length: Specifies the length of the
transmit queue.
Transmit Queue Max Length: Specifies the maximum
length of the transmit queue.
Result Data Type: Specifies the data type of the data value produced.
Unit: Specifies the unit number.
