Target Category: Linux Raspberry Pi
Target Sub-Category: Sim
Description: The input values of the actual GPIO Out block will appear on the output of the GPIO Out block during a simulation.
Bit Width: Specifies the number of contiguous bits to read in.
Channel: Indicates the channel number. Click here for Raspberry Pi pin mapping.
Offset: Specifies the offset into the digital port register.
Port: Specifies the digital register. Click here for Raspberry Pi pin mapping.
