The source code for the C support library comprises the following files:
File name |
Description |
CG.C |
Main driver routines |
CG.H |
Function prototypes |
CGEN.H |
Structure definitions |
CGIO.C |
File I/O |
CGIO.H |
CROSSDET.C |
Cross detection |
CROSSDET.H |
FILEIO.C |
File parsing |
FILEIO.H |
IMPORT.C |
File import/export |
IMPORT.H |
MAT.C |
Matrix operations |
MAT.H |
MATDIV.C |
Matrix divide |
MATDIV.H |
READCC. TXT |
ASCII text file containing additional technical information and corrections to the manual |
SIMIO.H |
VCSRC.MAK |
C code source make file for Microsoft Visual Studio |
XFER.C |
Transfer function support |
XFER.H |
UNIX.MAK |
Make file for Unix platforms |
VCSRC.MAK |
Project for Microsoft Visual C |
