A 16-bit and 32-bit Texas Instruments DMC block set is included with Embed. The 16-bit block set applies to the C2407 series; the 32-bit block set applies to the F280x series.
Additional Information: Texas Instruments C2407 document.
See Also:
Similarities and differences between 16-bit and 32-bit TI DMC block
ACI Motor
ACI Flux Estimator
ACI Speed Estimator
Clarke Transform
Current Model
Inverse Clarke Transform
Inverse Park Transform
Park Transform
Phase Voltage Calc
QEP Speed
PID Regulator
Ramp Generator
Resolver Decoder
SMO Position Estimator
Space Vector Generator (Magnitude/Frequency)
Space Vector Generator (Quadrature Control)
Space Vector PWM
Speed Calculator
V/Hz Profile Generator
