Embedded Category: F280x
Block Category: TI 32-bit DMC
Operating Mode Availability
•Simulation mode: YES
•C code generation mode: YES
The Space Vector Generator (Quadrature Control) block calculates the appropriate duty ratios needed to generate a given stator reference voltage using space vector PWM technique. The stator reference voltage is described by its magnitude and frequency.
