Most blocks and State Chart elements do not require a foreign RTOS in order to generate stand-alone C code: this happens automatically during the code generation process. However, some blocks are translated into either an ASCII data stream or a call to an EMPTY function. If you require the generated code for these blocks, you will need to purchase the Embed/Core Source Code Library.
The following tables show how standard and OpenVision blocks and StateChart elements are treated during code generation.
