Target Category: Arduino
Target Sub-Category: Sim
Description: The PWM for Simulation block is used during simulation to produce a fixed-point value between 0 and 1 that is supplied to the PWM block.
Arduino Pin: Specifies the Arduino pin. Click here for Arduino pin mapping.
Atmel Pin: Indicates the Atmel pin that corresponds to the specified Arduino pin.
Prescaler: This parameter is ignored.
