Block Category: TI MotorWare
The Controller Write Property block writes a property of the Texas Instruments motor drive software.
Controller: Indicates the controller instantiation number (0 or 1). This value must match the Controller value in the Motor Control block.
Property: Specifies the property. For more information on the properties, see the Texas Instruments documentation.
