Using wirePositioner blocks, you can perform a connect–the–dot method of wiring. Since you control the placement of the wirePositioner blocks, it’s easy to draw a precise wiring path.
Because wirePositioner blocks do not take any additional computation time, you won’t see a decrease in performance during a simulation.
