There are two ways to determine the types of data entering and exiting blocks:
•Hover the pointer over a connector: the signal value and data type are displayed in a pop-up.
•Activate View > Data Types and de-activate View > Presentation Mode. Connectors are colored to indicate data type. The following table lists all the data types and their corresponding connector colors.
Data Type | |
Scaled Integer |
Float |
Double |
Structure |
Matrix COMPLEX |
Matrix double or COMPLEX |
String |
Char |
Short, integer, or enum ComboItem |
Long |
Unsigned char |
Unsigned short |
Unsigned long or void |
Pointer |
Note: For plots, polar plots, meters, and stripCharts, the input connectors reflect the color of the signal trace, not the data type.
