When the current level of the diagram is so large that it doesn’t all fit in the viewable part of the window, you can:
•Pan
o Roll the mouse wheel
o Drag the scroll bar thumb
o Right-click over a scroll bar and select the navigation option that corresponds with what you want to do
•Zoom
o Hold down the CTRL key and roll the mouse wheel
o Click the
toolbar buttons
o Use View > Zoom In and View > Zoom Out
Typically, larger, more complex diagrams should be divided into subsystems and encapsulated in compound blocks.
