Accessing standard blocks
The Blocks menu lists Embed’s standard blocks. These blocks—along with OpenVision blocks and State Chart blocks—are also listed in the Blocks and Diagram Browser|topic=Working with Block Diagrams. If you have the necessary add-on modules, you will also have access to Embedded blocks, Comm blocks, and Digital Power blocks.
Commonly used standard blocks are also assigned to toolbar buttons.
