Simulink Category: Discrete blocks
Embed Block Equivalent: stateSpace block
The corresponding stateSpace block must be set up as discrete. The stateSpace block also requires an additional file. The translator automatically generates the file. However, if arguments for the original block are complicated MATLAB expressions, the original expressions are written to a file that you must convert manually.
