Composite State Activity Manager
Actions
Entry: Code is executed on state entry.
Exit: Code is executed on state exit.
Do: Code is executed for each execution cycle that the state remains active.
On Trigger: Code is executed when the state is active and when the specified trigger is TRUE.
Add/Delete Action: Adds or deletes the action to Selected Actions.
Attach Breakpoint: Sets a breakpoint the state that causes the simulation to stop after the corresponding Embed time step is complete.
Available Triggers: Lists the available triggers. There are two built-in triggers: after() and every().
Deferred Triggers: Lists the deferred triggers.
Edit Behavior: Specifies the state behavior for  the corresponding action. State behavior is specified as C statements.
Log Message: Logs the specified message when a state behavior is executed.
