*MAT_ADD_DAMAGE_GISSMO
LS-DYNA Input Interface KeywordAdditional failure model defining the plastic strain at failure, function of stress triaxiality, strain rate, Lode angle, element size, and temperature.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_ADD_DAMAGE_GISSMO | |||||||
| mat_ID | DTYP | EL_REF | PTHICKFAIL | VOLFRAC | |||
| EPSF_ID | ECRIT | N | DCRIT | FADEXP | TAB_EL | ||
| FCT_SR | SHRF | BIAXF | FCT_DLIM | ||||
Definition
| mat_ID | Material identifier. (Integer) |
| DTYP | Damage Accumulation flag.
(Integer) |
| EL_REF | Reference element size for size scaling
table. Default = 1.0 (Real) |
| PTHICKFAIL | Number of integration points to element
failure. (Real) |
| VOLFRAC | Volume fraction of failed integration points
prior to solid element deletion (Only used for fully-integrated
and higher order solid elements). Default = 0.0 (Real) |
| EPSF_ID | Plastic strain at failure table or function identifier.
(Integer) |
| ECRIT | Scale factor for necking plastic strain table
identifier. (Real) |
| N | Damage accumulation exponent. Default = 1.0 (Real) |
| DCRIT | Critical damage for stress softening
triggering. Default = 0.0 (Real) |
| FADEXP | Exponent for damage-related stress fadeout:
| TAB_EL | Element size scaling table or function
| FCT_SR | Strain rate dependency function identifier. If the first strain rate value is negative in FCT_SR, logarithmic scale is assumed. (Integer) |
| SHRF | Lower stress triaxiality boundary for element
size scaling. Default = -1.0 (Real) |
| BIAXF | Upper stress triaxiality boundary for element
size scaling. Default = 1.0 (Real) |
| FCT_DLIM | Damage limit function scale factor. Default = 1.0 (Real) |
- This keyword maps to /FAIL/TAB2.
