*MAT_007 (BLATZ_KO_RUBBER)
LS-DYNA Input Interface KeywordThis keyword defines an isotropic, incompressible, Neo-Hookean hyperelastic material.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_007 or *MAT_BLATZ_KO_RUBBER | |||||||
| mat_ID | G | ||||||
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density. (Real) |
| G | Shear modulus. (Real) |
- This keyword maps to a New-Hookean incompressible material /MAT/LAW42 with Poisson's ratio = 0.463.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
