*MAT_054 (ENHANCED_COMPOSITE_DAMAGE)
LS-DYNA Input Interface KeywordDefines an orthotropic shell composite material for unidirectional layers with Chang-Chang failure model.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_054 or *MAT_ENHANCED_COMPOSITE_DAMAGE
mat_ID ρ i E1 E2 E3 ν MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8WjY=vipgYlh9vqqj=hEeeu0xXdbb a9frFj0=OqFfea0dXdd9vqai=hGuQ8kuc9pgc9q8qqaq=dir=f0=yq aiVgFr0xfr=xfr=xb9adbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqyVd4gaaa@3A61@ 12 ν 31 ν 32
G12 G23 G31 AOPT 2WAY TI
XP YP ZP A1 A2 A3 MANGLE
V1 V2 V3 D1 D2 D3 DFAILM DFAILS
TFAIL α MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabbaGcbaGaeqySdegaaa@3797@ FBRT
XC XT YC YT SC β
RATIO EPSF EPSR TSMD
SLIMT1 SLIMC1 SLIMT2 SLIMC2 SLIMSR NCYRED
LCXC LCXT LCYC LCYT LSSC
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
E1 Young’s modulus in material direction 1.
(Real)
[ Pa ]
E2 Young’s modulus in material direction 2.
(Real)
[ Pa ]
E3 Young’s modulus in material direction 3.
(Real)
[ Pa ]
ν MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8WjY=vipgYlh9vqqj=hEeeu0xXdbb a9frFj0=OqFfea0dXdd9vqai=hGuQ8kuc9pgc9q8qqaq=dir=f0=yq aiVgFr0xfr=xfr=xb9adbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqyVd4gaaa@3A61@ 12 Poisson’s ratio between directions 1 and 2.
(Real)
ν 31 Poisson’s ratio between directions 3 and 1.
(Real)
ν 32 Poisson’s ratio between directions 3 and 2.
(Real)
G12 Shear modulus in direction 12.
(Real)
[ Pa ]
G23 Shear modulus in direction 23.
(Real)
[ Pa ]
G31 Shear modulus in direction 31.
(Real)
[ Pa ]
AOPT Material axis flag.
= 0 (Default)
Orthotropic axes defined by element nodes.
= 1
Orthotropic axes defined by the vector between reference point and the solid center.
= 3
Orthotropic axes defined by Vector V and element normal vector.
= 4
Orthotropic axes defined with reference point and normal to vector V.
AOPT < 0
The absolute value AOPT is a coordinate system identifier which defines the orthotropic directions.
(Integer)
2WAY Flag to turn on 2-way fiber action. This option is available only for solid and thick shells.
= 0 (Default)
Standard unidirectional behavior, meaning fibers run only in the direction 1.
= 1
2-way fiber behavior, meaning fibers run in both the first and second directions. The meaning of the fields DFAILT, DFAILC, YC, YT, SLIMT2 and SLIMC2 are altered if this flag is set.
(Integer)
TI Flag to turn on transversal isotropic behavior for material solid elements.
= 0 (Default)
Standard unidirectional behavior.
= 1
Transversal isotropic behavior.
(Integer)
XP, YP, ZP Coordinates of reference point for AOPT = 1 and 4.
(Real)
A1, A2, A3 Vector defining first orthotropy direction for AOPT = 2.
(Real)
MANGLE Material angle for AOPT = 1 and 3.
(Real)
V1, V2, V3 A vector which in combination with element normal defines the first orthotropy direction for AOPT = 3 and 4.
(Real)
D1, D2, D3 Components of vector for AOPT = 2.
(Real)
DFAILM Maximum strain for matrix straining in tension or compression (active only if DFAILT > 0).
Default = 1E+10 (Real)
DFAILS Maximum tensorial shear strain (active only if DFAILT > 0).
TFAIL Time step for element deletion.
(Real)
[ s ]
α MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabbaGcbaGaeqySdegaaa@3797@ Shear stress parameter for the nonlinear term.
Default = 0.0 (Real)
FBRT Softening factor for fiber tensile stress.
= 0.0
Tensile stress is σ T 1 .
> 1.0
Tensile strength is σ T 1 reduced by FBRT after failure occurred in compressive matrix mode.
Default = 1.0 (Real)
XT Yield stress in tension in direction 1.
(Real)
[ Pa ]
XC Yield stress in compression in direction 1.
(Real)
[ Pa ]
YT Yield stress in tension in direction 2.
(Real)
[ Pa ]
YC Yield stress in compression in direction 2.
(Real)
[ Pa ]
SC Maximum shear stress.
(Real)
[ Pa ]
β Shear scaling factor.
Default = 0 (Real)
RATIO Percentage of layers which must fail before element deletion.
(Real)
EPSF Damage initiation transverse shear strain.
EPSR Final rupture transverse shear strain.
Default = 2E+10 (Real)
TSMD Transverse shear maximum damage.
Default = 0.90 (Real)
SLIMT1 Factor to determine the minimum stress limit after stress maximum XT is reached.
SLIMC1 Factor to determine the minimum stress limit after stress maximum XC is reached.
SLIMT2 Factor to determine the minimum stress limit after stress maximum YT is reached.
SLIMC2 Factor to determine the minimum stress limit after stress maximum YC is reached.
SLIMSR Factor to determine the minimum stress limit after stress maximum SC.
NCYRED Number of cycles for stress reduction from maximum to minimum.
Default = 1 (Integer)
LCXC Load curve identifier defining the tensile stress in direction 1 XC as a function of strain rate.
(Integer)
LCXT Load curve identifier defining the tensile stress in direction 1 XT as a function of strain rate.
(Integer)
LCYC Load curve identifier defining the tensile stress in direction 1 YC as a function of strain rate.
(Integer)
LCYT Load curve identifier defining the tensile stress in direction 1 YT as a function of strain rate.
(Integer)
LSSC Load curve identifier defining the tensile stress in direction 1 SC as a function of strain rate.
(Integer)
  1. This material law is mapped to /MAT/LAW127 (ENHANCED_COMPOSITE) and /FAIL/GENE1.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
