*MAT_156 (MUSCLE)
LS-DYNA Input Interface KeywordDefines a muscle model for safety applications. Used only with truss elements.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_156 or *MAT_MUSCLE | |||||||
| mat_ID | SR_MAX | STS_MAX | STR | CER | DAMP | ||
| FUNCT_1 | FUNCT_2 | FUNCT_3 | FUNCT_4 | ||||
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| SR_MAX | Maximum strain
rate. (Real) |
| STS_MAX | Maximum stress.
| STR | Strain at maximum
stress. (Real) |
| CER | Strain scale factor in analytical
exponential formula for FUNCT_4 =
0. (Real) |
| DAMP | Damping
coefficient. (Real) |
| FUNCT_1 | Activation stress factor versus time.
(Real) |
| FUNCT_2 | Active stress factor as function of strain.
(Real) |
| FUNCT_3 | Active stress factor as function of
strain rate.
(Integer) |
| FUNCT_4 | Stress factor as function of strain
for parallel elastic element.
(Integer) |
- This keyword maps to /PROP/TYPE46 (SPR_MUSCLE).
- This keyword is used only with truss elements. Truss area input is mandatory.
- Total stress in the element is computed as:Where,
- Contractile stress
- Passive stress
- Damping stress
With , , and .
- If
FUNCT_4 = 0, the passive stress
factor is defined with:
- If
- If and
- If and
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
