*MAT_063 (CRUSHABLE_FOAM)
LS-DYNA Input Interface KeywordThis keyword defines a crushable foam material with optional tension cutoff and elastic unloading.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_063 or *MAT_CRUSHABLE_FOAM | |||||||
| mat_ID | E | Fct_ID | |||||
Definition
| mat_ID | Material
identifier. (Integer) |
| Initial
density. (Real) |
| E | Young’s
modulus. (Real) |
| Poisson’s ratio. Default = 0 (Real) |
| Fct_ID | Yield stress as a function of
volumetric strain function identifier. (Integer) |
| Maximum tensile
stress. (Real) |
- This keyword maps to /MAT/LAW33 (FOAM_PLAS).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
