*INTERFACE_SPRINGBACK
LS-DYNA Input Interface KeywordDescribes the variables to output in an initial state file or DYNAIN file at the end of the analysis.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *INTERFACE_SPRINGBACK_{OPTION1} | |||||||
| PSID | NTHHSV | ||||||
If OPTC = OPTCARD, read:
| OPTC | SLDO | NDFLAG |
Definition
| OPTION1 |
| PSID | Part set
identifier. (Integer) |
| NTHHSV | Nodal temperature.
(Integer) |
| OPTC | Optional card is read if
OPTC =
OPTCARD. (Character) |
| SLDO | Solid orthotropic directions.
(Integer) |
| NDFLAG | Node output option.
(Integer) |
