*MAT_081 (PLASTICITY_WITH_DAMAGE)
LS-DYNA Input Interface KeywordDefines an isotropic elasto-plastic material using tabulated stress versus plastic strain input for different strain rates and simple damage model.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_081 or *MAT_PLASTICITY_WITH_DAMAGE
mat_ID ρ i E ν SIGY ETAN FAIL
C P LCSS LCSR EPS_max VP Numint
EPS1 EPS2 EPS3 EPS4 EPS5 EPS6 EPS7 EPS8
ES1 ES2 ES3 ES4 ES5 ES6 ES7 ES8
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
E Young’s modulus.
(Real)
[ Pa ]
v Poisson’s ratio.
Default = 0 (Real)
SIGY Yield stress, ignored if LCSS > 0 or stress-strain values EPS1-EPS8, ES1-ES8 specified.
(Real)
[ Pa ]
ETAN Plastic hardening modulus, not used if LCSS > 0.
(Real)
[ Pa ]
FAIL Plastic strain for material softening (used only if FAIL > 0).
(Real)
C Strain rate coefficient.
(Real)
[ 1 s ]
P Strain rate exponent.
(Real)
LCSS Stress versus plastic strain curve or table identifier.
(Integer)
[ Pa ]
LCSR Curve identifier defining the scaling coefficient for the stress-strain curve for a corresponding strain rate.
(Integer)
EPS_max Plastic strain for element deletion (used only if EPS_max > 0).
(Real)
VP Strain rate type flag:
0
Total strain rate.
1
Plastic strain rate.
(Integer)
EPS1-EPS8 Plastic strain data points.
(Real)
ES1-ES8 Yield stress data points.
(Real)
[ Pa ]
  1. This keyword maps to /MAT/LAW36 (PLAS_TAB) or /MAT/LAW44 (COWPER) according to the input.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
