*MAT_074 (ELASTIC_SPRING_DISCRETE_BEAM)
LS-DYNA Input Interface KeywordThis keyword defines a nonlinear elasto-plastic discrete beam material with one DOFs and optional preload option.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_074 or *MAT_ELASTIC_SPRING_DISCRETE_BEAM
mat_ID ρ i K F0 D FC FT
LCF LCD C1 C2 V0
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
K LCF=0: Stiffness.
LCF>0: Scaling coefficient for curve LCF ordinate.
(Real)
[ N m ]
F0 Initial force.
(Real)
[ N ]
D Linear damping coefficient.
(Real)
FC, FT Failure elongation in compression and in tension (both should be input as positive values).
(Real)
[ m ]
LCF Force versus displacement curve identifier.
(Integer)
LCD Damping force versus velocity identifier.
(Integer)
C1, C2 Nonlinear damping coefficients.
V0 Reference velocity for nonlinear damping calculation. [ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
  1. This keyword maps to /MAT/LAW113 (SPR_BEAM) with one DOF.
  2. Stiffness direction is defined by coordinate system referenced in *SECTION_BEAM. This is global coordinate system by default.
  3. Beams with zero initial length are recommended.
  4. The material is only used with *SECTION_BEAM, ELFORM = 6 discrete beam elements.
  5. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
