2026
This manual provides a list of LS-DYNA input files available in Radioss.
View new features for Radioss 2026.
Radioss is a leading explicit finite element solver for crash and impact simulation.
Current Radioss format uses the 12x extension format.
LS-DYNA Input Interface KeywordThis model defines a one-chambered airbag filed by adiabatic gas. Uniform pressure method is used.
LS-DYNA Input Interface KeywordThis model defines a control volume filled with a liquid.
LS-DYNA Input Interface KeywordThis model defines a one-chambered airbag with pressure specified as function of time.
LS-DYNA Input Interface KeywordDefines a Finite Volume Method airbag.
LS-DYNA Input Interface KeywordDefine the reference state for elements belonging to a part using given element and node identifiers with possible scaling for the nodes with defined scale center and scale factor.
LS-DYNA Input Interface KeywordThis model defines a one-chambered airbag with uniform pressure method, injected gas and vent hole.
LS-DYNA Input Interface KeywordDescribes a one-chambered airbag with pressure as a function of volume.
LS-DYNA Input Interface KeywordDefine solid and hourglass formulation for 8-node solid elements.
LS-DYNA Input Interface KeywordDefine user-defined through the thickness integration rules for the composite shell element.
LS-DYNA Input Interface KeywordDescribes the variables to output in an initial state file or DYNAIN file at the end of the analysis.
LS-DYNA Input Interface KeywordThis keyword should always be the first card of the input file. Optionally used with *CONTROL_UNITS card to specify model units.
LS-DYNA Input Interface KeywordDefines a node number and nodal coordinates in the global coordinate system.
LS-DYNA Input Interface KeywordDefines a part, which combines material and property information.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
