2026
This manual provides a list of LS-DYNA input files available in Radioss.
View new features for Radioss 2026.
Radioss is a leading explicit finite element solver for crash and impact simulation.
Current Radioss format uses the 12x extension format.
LS-DYNA Input Interface KeywordDefine solid and hourglass formulation for 8-node solid elements.
LS-DYNA Input Interface KeywordDefine user-defined through the thickness integration rules for the composite shell element.
LS-DYNA Input Interface KeywordDescribes the variables to output in an initial state file or DYNAIN file at the end of the analysis.
LS-DYNA Input Interface KeywordThis keyword should always be the first card of the input file. Optionally used with *CONTROL_UNITS card to specify model units.
LS-DYNA Input Interface KeywordDefines a node number and nodal coordinates in the global coordinate system.
LS-DYNA Input Interface KeywordDefines a part, which combines material and property information.
LS-DYNA Input Interface KeywordDefines finite element property of beams, trusses, and discrete beams.
LS-DYNA Input Interface KeywordThis keyword defines finite element property of spring elements.
LS-DYNA Input Interface KeywordDefines finite element property of seatbelt elements.
LS-DYNA Input Interface KeywordDefines the shell element properties.
LS-DYNA Input Interface KeywordDefines the finite element properties of solid elements.
LS-DYNA Input Interface KeywordDefines the finite element properties of thick shell elements.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
