2026
This manual provides a list of LS-DYNA input files available in Radioss.
View new features for Radioss 2026.
Radioss is a leading explicit finite element solver for crash and impact simulation.
Current Radioss format uses the 12x extension format.
LS-DYNA Input Interface KeywordDefine solid and hourglass formulation for 8-node solid elements.
LS-DYNA Input Interface KeywordDefine user-defined through the thickness integration rules for the composite shell element.
LS-DYNA Input Interface KeywordDescribes the variables to output in an initial state file or DYNAIN file at the end of the analysis.
LS-DYNA Input Interface KeywordThis keyword should always be the first card of the input file. Optionally used with *CONTROL_UNITS card to specify model units.
LS-DYNA Input Interface KeywordDefines an acceleration load or centrifugal load.
LS-DYNA Input Interface KeywordDescribes the set of part(s) on which the load body is applied. Load body is defined with *LOAD_BODY_{OPTION}.
LS-DYNA Input Interface KeywordDefines gravity load applied to a part or to a set of parts.
LS-DYNA Input Interface KeywordDefines a concentrated force or moment applied on a defined node or to each node of a nodal set.
LS-DYNA Input Interface KeywordDefines a concentrated force or moment applied on main node of a defined rigid body.
LS-DYNA Input Interface KeywordDefines pressure load on a segment defined by node or by set of segments.
LS-DYNA Input Interface KeywordDefines pressure load on a single shell element or on a set of shell elements.
LS-DYNA Input Interface KeywordDefines a node number and nodal coordinates in the global coordinate system.
LS-DYNA Input Interface KeywordDefines a part, which combines material and property information.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
