*INTEGRATION_SHELL
LS-DYNA Input Interface KeywordDefine user-defined through the thickness integration rules for the composite shell element.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *INTEGRATION_SHELL | |||||||
| IRID | N | ESOP | |||||
If ESOP=0, defines N
                    cards
| Zi | Wi | PART_IDi |
Definition
| IRID | Integration card
                                        identifier. Default = 100 (Integer) | |
| N | Number of integration points
                                    through the thickness. (Integer) | |
| ESOP | Integration point distribution
 (Integer) | |
| Zi | Coordinate of integration point in
                                    range -1 to 1. (Real) | |
| Wi | Weighting factor. Thickness associated to the integration point divided by the total shell thickness. (Real) | |
| PART_IDi | Optional: Part identifier to
                                    specify the material used for the integration point. If not defined, the material of the shell element is used. (Integer) |
- This keyword maps to /PROP/TYPE19 (PLY) and /PROP/TYPE51.
