*INITIAL_VELOCITY_RIGID_BODY
LS-DYNA Input Interface KeywordDefine initial velocity of a rigid body.
(1) (2) (3) (4) (5) (6) (7) (8)
Part_ID VX VY VZ VXR VYR VZR Skew_ID
Definition
Part_ID Part ID of the rigid body or nodal rigid body.
(Integer)
VX, VY, VZ Translational nodal velocity components.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
VXR, VYR, VZR Rotational nodal velocity components.
(Real)
[ rad s ]
Skew_ID Coordinate system identifier.
(Integer)
  1. This keyword maps to /INIVEL.
  2. This setting can be overwritten by the other *INITIAL_VELOCITY defined in the model.
