*INITIAL_STRESS_SHELL_{OPTION}
LS-DYNA Input Interface KeywordDefines the reference state for elements belonging to a part, using given nodal coordinates.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*INITIAL_STRESS_SHELL | |||||||
EID | npg | nb_integr | LARGE |
*INITIAL_STRESS_SHELL_SET | |||||||
SID | npg | nb_integr | LARGE |
T | SIGXX | SIGYY | SIGZZ | SIGXY | SIGYZ | SIGZX | EPSP |
T | SIGXX | SIGYY | SIGZZ | SIGYZ | |||||
SIGZX | SIGZX | EPSP |
Definition
OPTION |
EID | 4 or 3 node shell element
identifier. (Integer) |
SID | Part set
npg | Number of Gauss point in plane.
(Integer) |
nb_integr | Integration point number through
the thickness. (Integer) |
LARGE | Format size.
(Integer) |
T | Through thickness integration point
parametric position between -1 and 1. (Real) |
SIGij | Stress value in the direction
ij. (Real) |
EPSP | Plastic strain. |
- This keyword maps to /INISHE/STRS_F/GLOB or /INISH3/STRS_F/GLOB.
- If
npg=4, the Gauss integration points
in the plane are stored in the following order:
(1) - One stress card is added for each integration through the thickness and each Gauss points.
