2026
This manual provides a list of LS-DYNA input files available in Radioss.
View new features for Radioss 2026.
Radioss is a leading explicit finite element solver for crash and impact simulation.
Current Radioss format uses the 12x extension format.
LS-DYNA Input Interface KeywordDefines a beam, discrete beam, or a truss element.
LS-DYNA Input Interface KeywordDefines a 1 degree of freedom spring element.
LS-DYNA Input Interface KeywordThis keyword defines mass added to nodes or node sets.
LS-DYNA Input Interface KeywordThis keyword defines mass added to parts or part sets.
LS-DYNA Input Interface KeywordDefines a spring element without any stiffness for visualization.
LS-DYNA Input Interface KeywordDefines a 1D seat belt element.
LS-DYNA Input Interface KeywordThis keyword defines an accelerometer.
LS-DYNA Input Interface KeywordDefines a 1D seat belt pretensioner element.
LS-DYNA Input Interface KeywordDefines a 1D seat belt retractor element.
LS-DYNA Input Interface KeywordDefines a seat belt sensor.
LS-DYNA Input Interface KeywordDefines a 1D or 2D seat belt slipring.
LS-DYNA Input Interface KeywordDefines a shell element with 3 or 4 nodes.
LS-DYNA Input Interface KeywordDefines 3-dimensional solid elements.
LS-DYNA Input Interface KeywordDefines a Smooth Particle Hydrodynamic (SPH).
LS-DYNA Input Interface KeywordDefines 3-dimensional thick shell elements.
LS-DYNA Input Interface KeywordDefine solid and hourglass formulation for 8-node solid elements.
LS-DYNA Input Interface KeywordDefine user-defined through the thickness integration rules for the composite shell element.
LS-DYNA Input Interface KeywordDescribes the variables to output in an initial state file or DYNAIN file at the end of the analysis.
LS-DYNA Input Interface KeywordThis keyword should always be the first card of the input file. Optionally used with *CONTROL_UNITS card to specify model units.
LS-DYNA Input Interface KeywordDefines a node number and nodal coordinates in the global coordinate system.
LS-DYNA Input Interface KeywordDefines a part, which combines material and property information.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
