*ELEMENT_SEATBELT_SLIPRING
LS-DYNA Input Interface KeywordDefines a 1D seat belt slipring.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*ELEMENT_SEATBELT_SLIPRING | |||||||
SID | El_ID1 | El_ID2 | Fric_d | node_ID1 | Ltime | Fric_s | node_ID2 |
A | Fl_flag | Ed_factor | fct_ID2 | fct_ID4 |
Definition
SID | Slipring
identifier. (Integer) |
El_ID1 | First element identifier in
slipring. (Integer) |
El_ID2 | Second element identifier in
Fric_d | Coulomb dynamic friction
coefficient. (Real) |
node_ID1 | Slipring node
Ltime | Lockup time. (Real) |
Fric_s | (Optional) Coulomb static friction
node_ID2 | (Optional) Orientation node
A | (Optional) Coefficient for
determining Coulomb friction coefficient. (Real) |
Fl_flag | Direction of belt movement.
Ed_factor | (Optional) Decay constant for
friction coefficient computation. (Real) |
fct_ID2 | (Optional) Curve identifier
defining dynamic coefficient of friction as a function of normal
force. (Integer) |
fct_ID4 | (Optional) Curve identifier
defining static coefficient of friction as a function of normal
force. (Integer) |
- This keyword maps to /SLIPRING/SPRING and /SENSOR/TIME.
