*HOURGLASS
LS-DYNA Input Interface KeywordDefine solid and hourglass formulation for 8-node solid elements.
(1) (2) (3) (4) (5) (6) (7) (8)
*HOURGLASS
HGID IHG QH
Definition
HGID Hourglass identifier used in *PART.
(Integer)
IHG 8-node solid and hourglass formulation.
= 1, 2, 3 (Default)
The solid formulation is defined in *SECTION_SOLID.
= 4, 5
Standard 8-node solid element, one integration point. Elastic stiffness hourglass formulation with orthogonal and rigid deformation modes compensation (Belytschko).
= 6, 7
HEPH 8-node solid element, 1 Gauss integration point, co-rotational system formulation, physical hourglass stabilization.
(Real)
QH Hourglass coefficient.
Default = 0.1 (Real)
  1. This keyword maps to /PROP/TYPE14 (SOLID).
  2. IHG=5 is available only for isotropic materials.
  3. Parameters defined in this option overwrite values defined in *CONTROL_HOURGLASS.
