2026
This manual provides a list of LS-DYNA input files available in Radioss.
View new features for Radioss 2026.
Radioss is a leading explicit finite element solver for crash and impact simulation.
Current Radioss format uses the 12x extension format.
LS-DYNA Input Interface KeywordDefine automatic single contact for airbags.
LS-DYNA Input Interface KeywordDefine nodes of beam elements to surface contact interface.
LS-DYNA Input Interface KeywordDefine an automatic general contact interface between elements.
LS-DYNA Input Interface KeywordDefine nodes to surface contact interface.
LS-DYNA Input Interface KeywordDefine surface to surface contact between a set of shell and solid elements.
LS-DYNA Input Interface KeywordDefine automatic single contact interface between elements.
LS-DYNA Input Interface KeywordDefine automatic single contact interface set of shell and solid elements.
LS-DYNA Input Interface KeywordAccumulates output for contact forces (from other existing contacts) acting on a given set of nodes/segments determined by set, part or subset with optional selection of interacting main side contact entities and intersection between sets and boxes.
LS-DYNA Input Interface KeywordDefine an interior contact for each part defined in the defined set of parts.
LS-DYNA Input Interface KeywordDefine nodes to surface contact interface dedicated for spotweld connection.
LS-DYNA Input Interface KeywordDefines tied contact between entities without failure.
LS-DYNA Input Interface KeywordDefines tied contact between entities.
LS-DYNA Input Interface KeywordDefine solid and hourglass formulation for 8-node solid elements.
LS-DYNA Input Interface KeywordDefine user-defined through the thickness integration rules for the composite shell element.
LS-DYNA Input Interface KeywordDescribes the variables to output in an initial state file or DYNAIN file at the end of the analysis.
LS-DYNA Input Interface KeywordThis keyword should always be the first card of the input file. Optionally used with *CONTROL_UNITS card to specify model units.
LS-DYNA Input Interface KeywordDefines a node number and nodal coordinates in the global coordinate system.
LS-DYNA Input Interface KeywordDefines a part, which combines material and property information.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
