*CONTACT_INTERIOR
LS-DYNA Input Interface KeywordDefine an interior contact for each part defined in the defined set of parts.
(1) (2) (3) (4) (5) (6) (7) (8)
*CONTACT_INTERIOR
set_ID1 set_ID2 set_ID3 set_ID4 set_ID5 set_ID6 set_ID7 set_ID8
Definition
set_ID1 - set_ID8 Set of part identifier.
(Integer)
  1. This keyword maps to Icontrol = 1 in the solid properties.
