*CONTACT_ERODING_NODES_TO_SURFACE
LS-DYNA Input Interface KeywordDefine nodes to surface contact interface.
(1) (2) (3) (4) (5) (6) (7) (8)
*CONTACT_ERODING_NODES_TO_SURFACE_{OPTION3}
If OPTION3 = ID or TITLE, insert the following line
inter_ID Title
SSID MSID SSTYP MSTYP
FS FD DC Tstart Tstop
SFS SFM SST MST SFTS SFMT FSF
Blank card
Optional Card A
SOFT
Definition
OPTION3
ID
Include a contact identifier.
TITLE
Include a title.
inter_ID Contact interface identifier.
(Integer)
Title Contact interface title.
(Character, maximum 70 characters)
SSID Secondary set or part identifier.
(Integer)
MSID Main set or part identifier.
(Integer)
SSTYP Input secondary set type.
= 0
Segment set ID
= 1
Shell element set ID
= 2
Part set ID
= 3
Part ID
= 4
Node set ID
= 5
All parts (SID is ignored).
= 6
Part set ID. All parts are included in the contact, except the one defined in the part set ID.
= 7
Subset set ID
(Integer)
MSTYP Input main set type.
= 0
Segment set ID
= 1
= 2
Part set ID
= 3
Part ID
= 5
= 6
= 7
Subset set ID
(Integer)
FS Static friction coefficient.
(Real)
FD Dynamic friction coefficient.
(Real)
DC Exponential decay coefficient.
(Real)
[ s m ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaadohaaeaacaWGTbaaaaGaay5waiaaw2faaaaa@39E3@
Tstart Start time.
(Real)
[ s ]
Tstop Stop time.
Default = 1E+30 (Real)
[ s ]
SFS Secondary stiffness scale factor.
(Real)
SFM Main stiffness scale factor.
(Real)
SST Secondary maximum gap value.
(Real)
[ m ]
MST Main maximum gap value.
(Real)
[ m ]
SFTS Secondary contact gap scale.
(Real)
SFMT Main contact gap scale.
(Real)
FSF Coulomb friction coefficient scale factor.
(Real)
SOFT Contact stiffness definition flag.
= 0
Contact stiffness is the average of the main and secondary stiffness.
= 1
Contact stiffness is the minimum of the main and secondary stiffness.
= 2
Contact stiffness is based on the average of the main and secondary stiffness and time step stability condition.
(Integer)
  1. This keyword maps to /INTER/TYPE25.
