*CONTACT_TIED
LS-DYNA Input Interface KeywordDefines tied contact between entities.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*CONTACT_TIED_OPTION_{OPTION3} |
inter_ID | Title |
SSID | MSID | SSTYP | MSTYP | ||||
Blank line | |||||||
SST | MST | SFST | SFMT |
Definition
OPTION |
OPTION3 |
inter_ID | Contact ID. (Integer) |
TITLE | Contact title (only OPTION3 =
ID is defined). (Character) |
SSID | Secondary nodal set. (Integer) |
MSID | Main surface set. (Integer) |
SSTYP | Input secondary set type.
(Integer) |
MSTYP | Input main set type.
(Integer) |
SST | Secondary maximum gap value. (Real) |
MST | Main maximum gap value. (Real) |
SFTS | Secondary contact gap scale. (Real) |
SFMT | Main contact gap scale. (Real) |
- This keyword maps to /INTER/TYPE2 with Spotflag = 28 or /INTER/TYPE10.
