*CONTACT_AUTOMATIC_SINGLE_SURFACE
LS-DYNA Input Interface KeywordDefine automatic single contact interface between elements.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *CONTACT_AUTOMATIC_SINGLE_SURFACE_{OPTION3} | |||||||
If OPTION3 = ID or TITLE, insert
the following line.
| inter_ID | Title | ||||||
| SSID | SSTYP | ||||||
| FS | FD | DC | Tstart | Tstop | |||
| SFS | SST | SFTS | FSF |
Optional Card A
| SOFT |
Optional Card B
Optional Card C
| DTSTIF |
Definition
| OPTION3 |
| inter_ID | Contact interface identifier. (Integer) |
| Title | Contact interface title. (Character, maximum 70 characters) |
| SSID | Set or part identifier. (Integer) |
| SSTYP | Input set type.
(Integer) |
| FS | Static friction coefficient. (Real) |
| FD | Dynamic friction coefficient. (Real) |
| DC | Exponential decay coefficient. (Real) |
| Tstart | Start time. (Real) |
| Tstop | Stop time. Default = 1E+30 (Real) |
| SST | Stiffness scale factor. (Real) |
| SFS | Maximum gap value. (Real) |
| SFTS | Contact gap scale. (Real) |
| FSF | Coulomb friction coefficient scale
factor. (Real) |
| SOFT | Contact stiffness definition flag.
(Integer) |
| DTSTIF | Time step used for stiffness
calculation. Used only if SOFT >
0. (Real) |
- This keyword maps to /INTER/TYPE25.
