2026
This manual provides a list of LS-DYNA input files available in Radioss.
View new features for Radioss 2026.
Radioss is a leading explicit finite element solver for crash and impact simulation.
Current Radioss format uses the 12x extension format.
LS-DYNA Input Interface KeywordDefine solid and hourglass formulation for 8-node solid elements.
LS-DYNA Input Interface KeywordDefines initial axial force applied to beams as function of time.
LS-DYNA Input Interface KeywordDefines the reference state for elements belonging to a part, using given nodal coordinates.
LS-DYNA Input Interface KeywordInitializes the strain for shell elements in the global coordinate system.
LS-DYNA Input Interface KeywordInitializes the stress for solid elements in the global coordinate system.
LS-DYNA Input Interface KeywordDefines initial velocity of a node set.
LS-DYNA Input Interface KeywordDefine both translational and rotational initial velocities.
LS-DYNA Input Interface KeywordThis keyword defines an initial translational and rotational velocity of a node.
LS-DYNA Input Interface KeywordDefine initial velocity of a rigid body.
LS-DYNA Input Interface KeywordDefine user-defined through the thickness integration rules for the composite shell element.
LS-DYNA Input Interface KeywordDescribes the variables to output in an initial state file or DYNAIN file at the end of the analysis.
LS-DYNA Input Interface KeywordThis keyword should always be the first card of the input file. Optionally used with *CONTROL_UNITS card to specify model units.
LS-DYNA Input Interface KeywordDefines a node number and nodal coordinates in the global coordinate system.
LS-DYNA Input Interface KeywordDefines a part, which combines material and property information.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
