*INITIAL_STRAIN_SHELL
LS-DYNA Input Interface KeywordInitializes the strain for shell elements in the global coordinate system.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *INITIAL_STRAIN_SHELL | |||||||
| ELE_ID | npg | nb_integr | LARGE | ||||
For each in plane point npg and for each integration point nb_integr.
If LARGE = 0:
| EPSxx | EPSyy | EPSzz | EPSxy | EPSyz | EPSzx | T |
If LARGE = 1:
| EPSxx | EPSyy | EPSzz | EPSxy | EPSyz | |||||
| EPSzx | T | ||||||||
Definition
| ELE_ID | 3 nodes or 4 nodes shell element
identifier. (Integer, maximum 10 digits) |
| npg | Number of in-plane integration points. | |
| nb_integr | Number of integration point through the thickness. | |
| LARGE | Line format flag:
| EPSxx | Strain tensor component xx in the global coordinate system. | |
| EPSyy | Strain tensor component yy in the global coordinate system. | |
| EPSzz | Strain tensor component zz in the global coordinate system. | |
| EPSxy | Strain tensor component xy in the global coordinate system. | |
| EPSyz | Strain tensor component yz in the global coordinate system. | |
| EPSzx | Strain tensor component zx in the global coordinate system. | |
| T | Parametric position of the integration points throughout the thickness (between -1 and 1 inclusive). |
- This keyword maps to /INISHE/STRA_F/GLOB or /INISH3/STRA_F/GLOB.
- If npg and nb_integr are not defined (set to 0), only the outer and the inner layer are set in the card.
