2026
This manual provides a list of LS-DYNA input files available in Radioss.
View new features for Radioss 2026.
Radioss is a leading explicit finite element solver for crash and impact simulation.
Current Radioss format uses the 12x extension format.
LS-DYNA Input Interface KeywordDefine solid and hourglass formulation for 8-node solid elements.
LS-DYNA Input Interface KeywordDefine user-defined through the thickness integration rules for the composite shell element.
LS-DYNA Input Interface KeywordDescribes the variables to output in an initial state file or DYNAIN file at the end of the analysis.
LS-DYNA Input Interface KeywordThis keyword should always be the first card of the input file. Optionally used with *CONTROL_UNITS card to specify model units.
LS-DYNA Input Interface KeywordDefines a node number and nodal coordinates in the global coordinate system.
LS-DYNA Input Interface KeywordDefines a part, which combines material and property information.
LS-DYNA Input Interface KeywordThis keyword defines a set of beams based on a list of beams in various ways.
LS-DYNA Input Interface KeywordDefines a set of beam elements based on a list of set of beam elements.
LS-DYNA Input Interface KeywordThis keyword defines a set from the intersection of set lists of beam elements.
LS-DYNA Input Interface KeywordDefines a set of springs based on a list of springs in various ways.
LS-DYNA Input Interface KeywordDefines a set of discrete elements based on a list of set of discrete elements.
LS-DYNA Input Interface KeywordThis keyword defines a set of from the intersection of set lists of discrete elements.
LS-DYNA Input Interface KeywordDefines a set of nodes based on a list of nodes in various ways.
LS-DYNA Input Interface KeywordThis keyword defines a set of nodes from a list of existing sets.
LS-DYNA Input Interface KeywordThis keyword defines a set from the intersection of set lists of nodes.
LS-DYNA Input Interface KeywordDefines a set of parts based on a list or generates a list by specifying a range of part IDs.
LS-DYNA Input Interface KeywordThis keyword defines a set of parts from a list of existing part sets.
LS-DYNA Input Interface KeywordDefines a surface defined by 3 or 4 node segments.
LS-DYNA Input Interface KeywordDefines a set of segments based on a list of set of segments.
LS-DYNA Input Interface KeywordThis keyword defines a set from the intersection of set lists of segments.
LS-DYNA Input Interface KeywordThis keyword defines a set of shells based on a list of shells in various ways.
LS-DYNA Input Interface KeywordDefines a set of shell elements based on a list of set of shell elements.
LS-DYNA Input Interface KeywordThis keyword defines a set from the intersection of set lists of shell elements.
LS-DYNA Input Interface KeywordThis keyword defines a set of solids based on a list of solids in various ways.
LS-DYNA Input Interface KeywordDefines a set of solid elements based on a list of sets of solid elements.
LS-DYNA Input Interface KeywordThis keyword defines a set from the intersection of set lists of solid elements.
This manual contains the description of the keywords for the Radioss Multi-Domain.
Keywords that are still supported, but no longer maintained (*) are considered obsolete.
