*SET_SHELL
LS-DYNA Input Interface KeywordThis keyword defines a set of shells based on a list of shells in various ways.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *SET_SHELL_{OPTION1}_{OPTION2} | |||||||
| set_ID | |||||||
| E_ID1 | E_ID2 | E_ID3 | E_ID4 | E_ID5 | E_ID6 | E_ID7 | E_ID8 |
| E_IDB1 | E_IDE1 | E_IDB2 | E_IDE2 | E_IDB3 | E_IDE3 | E_IDB4 | E_IDE4 |
| E_IDB | E_IDE | INCR |
| TYPE | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 |
| ID8 | ID9 | ID10 | ID11 | ID12 | etc |
| E_ID |
Definition
| OPTION1 |
| OPTION2 |
| set_ID | Set identifier. (Integer) |
| E_ID1 -E_ID8 | Element IDs, 8 per line. (Integer) |
| E_IDB1-E_IDB4 | First element ID of the range, 4 ranges per
line. (Integer) |
| E_IDE1-E_IDE4 | Last element ID of the range, 4 ranges per
line. (Integer) |
| E_IDB | First element ID of the range. (Integer) |
| E_IDE | Last element ID of the range. (Integer) |
| INCR | Increment value for the list generation from
E_IDB to
E_IDE. Default = 1 (Integer) |
| TYPE |
| ID1, ID2, ID3 | Entity IDs, 7 per line. (Integer) |
| E_ID | Element ID's. (Integer) |
- This keyword maps to /SET.
- The adding and removing of elements in *SET_SHELL_GENERAL depends on the order of the TYPE options used.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
