*SET_SOLID_INTERSECT
LS-DYNA Input Interface KeywordThis keyword defines a set from the intersection of set lists of solid elements.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*SET_SOLID_INTERSECT | |||||||
set_ID |
Repeat the following line, as needed.
set_ID1 | set_ID2 | set_ID3 | set_ID4 | set_ID5 | set_ID6 | set_ID7 | set_ID8 |
Definition
set_ID | Set identifier. (Integer) |
set_IDi | Discrete set ID's. (Integer) |
- This keyword maps to /SET/GENERAL.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
