*SET_NODE_INTERSECT
LS-DYNA Input Interface KeywordThis keyword defines a set from the intersection of set lists of nodes.
(1) (2) (3) (4) (5) (6) (7) (8)
*SET_NODE_INTERSECT
set_ID
Repeat the following line, as needed.
set_ID1 set_ID2 set_ID3 set_ID4 set_ID5 set_ID6 set_ID7 set_ID8
Definition
set_ID Node set identifier.
(Integer)
set_IDi Node Set ID's, 8 per line.
(Integer)
  1. This keyword maps to /SET/GENERAL.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
