*SET_PART_ADD
LS-DYNA Input Interface KeywordThis keyword defines a set of parts from a list of existing part sets.
(1) (2) (3) (4) (5) (6) (7) (8)
*SET_PART_ADD
set_ID
set_ID1 set_ID2 set_ID3 set_ID4 set_ID5 set_ID6 set_ID7 set_ID8
Definition
set_ID Part set identifier.
(Integer)
set_ID1 - set_ID8 Part Set IDs, 8 per line.
(Integer)
If a set_ID(n) is negative, all the sets in the range, set_ID(n-1) through |set_ID(n)| are included in the set.
  1. This keyword maps to /SET/GENERAL.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
