*SET_BEAM_INTERSECT
LS-DYNA Input Interface KeywordThis keyword defines a set from the intersection of set lists of beam elements.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *SET_BEAM_INTERSECT | |||||||
| set_ID | |||||||
Repeat the following line, as needed.
| set_ID1 | set_ID2 | set_ID3 | set_ID4 | set_ID5 | set_ID6 | set_ID7 | set_ID8 |
Definition
| set_ID | Set identifier. (Integer) |
| set_IDi | Beam element set ID's. (Integer) |
- This keyword maps to /SET/GENERAL.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
