*LOAD_GRAVITY_PART
LS-DYNA Input Interface KeywordDefines gravity load applied to a part or to a set of parts.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *LOAD_GRAVITY_PART_{OPTION} | |||||||
If OPTION = <Blank>
| PID | DOF | Fct_ID | Fscaley |
If OPTION = SET
| SID | DOF | Fct_ID | Fscaley |
Definition
| OPTION |
| PID | Part ID where gravity load is
applied. (Integer) |
| SID | Set part ID where gravity load is
| DOF | Direction of gravity load.
| Fct_ID | Curve identifier for gravity acceleration load as function of
time. (Integer) |
| Fscaley | Scaling coefficient applied to the ordinate of the gravity
curve. Default =1. 0 (Real) |
- This keyword maps to /GRAV.
