*LOAD_SEGMENT
LS-DYNA Input Interface KeywordDefines pressure load on a segment defined by node or by set of segments.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *LOAD_SEGMENT_OPTION1_{OPTION2} | |||||||
If OPTION1=<blank>
| Fct_ID | Fscaley | Tstart | node_ID1 | node_ID2 | node_ID3 | node_ID4 |
If OPTION1 = SET
| SSID | Fct_ID | Fscaley | Tstart |
If OPTION2 = ID
| ID | Title | ||||||
Definition
| OPTION1 |
| OPTION2 |
| SSID | Segment set
identifier. (Integer) |
| Title | Load
title. (Character) |
Title |
| Fct_ID | Pressure versus time load curve
| Fscaley | Ordinate (pressure) scale
factor. Default = 1.0 (Real) |
| Tstart | Time for pressure activation.
Function Fct_ID is shifted by
Tstart. Default = 0.0 (Real) |
| node_ID1 | Node identifier
1. (Integer) |
| node_ID2 | Node identifier
2. (Integer) |
| node_ID3 | Node identifier
3. (Integer) |
| node_ID4 | Node identifier 4 (optional for
triangular elements). (Integer) |
- This keyword maps to /PLOAD.
